I have the melomania 1s and they have often had connection issues , but when they work they do sound really good.
I also have the Air pod pros and I think the C and A pair beat them on sound, but what I would say about the air pods is they never ever fail to connect you take them out of the case and they just work!
I really fancy the new Melonania touch but I don’t need connection issues again.
Slow red flashing means charging.
If your right bud wouldn't respond at all then it might not be powered on.
Touch for 2 seconds should turn it on. If it doesn't turn on it might be out of power because it hasn't been charging.
If the bud is charging it should be slowly flashing red. If it is not charging it could be flashing white or blue as it might be trying to connect. Or it could have no light. Also, no light if fully charged.Do both earbuds light up red when charging?
So, no light could mean not charging or fully charged.
I have almost exactly this problem, but with the left; the right one always starts charging fine. Except with mine, the left seems to have dropped in properly and often just doesn't make that connection, even with a wiggle and press (sometimes makes partial contact and the light flickers, but charging doesn't start). To rectify this I keep having to take the left one out and drop it in again multiple times, it's so unreliable I've sent them back.
Do you have the same problem with having to lift it out and drop in again, and the flickering, or does yours always start charging if you just nudge it down properly?
If I nudge it down properly it usually starts charging but not always.
Also, once the case is closed I find that the right bud will often stop charging so it must be moving in the socket. I can tell because when they do connect to Bluetooth the app will show the left bud fully charged but the right bud not, and they've both been in the case for the same amount of time.
It's weekend so I'm still thinking about it but this could be the last straw for me. If there are physical issues with the case no amount of firmware updates will fix it.
Very disappointed.
In which case we have the exact same issue, but with opposite buds. I feel completely the same about it as a physical issue. Should be getting an exchange pair when mine arrive back at the warehouse next week, but I'd definitely return them. Talk to support about it and I'm sure they'll tell you the same as they told me.
Glad I haven't been experiencing connection drop outs but this is just as bad, and seemingly not fixable with a firmware update. I have a theory that the pins are making contact on the whole, but the charging just doesn't trigger properly. Again, real shame but I'd definitely send them back (hate how time-consuming the process is these days with deliveries).
Yup, that conversation is exactly relevant to my issue too. I just went through rest of the thread, and same issue pops up for several others. I now am starting to think this is a hardware issue with charging/case rather than connection issue that firmware update can fix. I'm on the verge of giving up & returning mine.
If anyone has figured out a workaround, I would be curious to know.
I don't think we should need a workaround for something costing this much.I get very little connection problems as I have a workaround routine.
Always remove the earbud from the case that-has connection to the phone first. In my case the left followed by the right. The left will flash white and connect to the phone followed by the right but not shown as connected which is correct. When I finish using them replace them in the case and both flash red for charging. If don’t flash red they are not seated correctly so you mayneed to jiggle as this will be down to any change in bud or tip change.
Works for me every time.
I started the thread as a first adopter to get users feedback over time and that’s what it’s there for good or bad. I’m happy with mine. They sit fine drawn in by the magnet but I always push them anyway until I see the red charging light so no connection issues for me as I withdraw them from the case, wait for them to connect and off I go.Hey. This is my first post in this thread but I have been following it as I'm extremely interested in buying the CA Melomania touch.
I have a couple questions to anyone who has got them. Please let me know if you have the latest firmware available.
1.) Are the connection issues a deal breaker? Is it only the occasional reset of the buds to get them to connect? Or is it multiple times a day to get them to connect?
Anyone else had the issues with charging where the right (or left) don't charge. Do you think this is the reason why they need a reset.
2.) Did you come to this thread because there was an issue? The reason for this is I'm trying to find if there may be a slight bias. As in people without issues are not going to search for a thread if you get what I mean.
Thanks.
That was working for me, until last night. I thought I'd leave them in the case and see what happened once left for a while. Nothing, just refuse to connect.I get very little connection problems as I have a workaround routine.
I've had 3 pairs of wireless buds from Cambridge. All sent back. 100% failure rate, and despite being over a 10month period, exactly the same issues.Hey. This is my first post in this thread but I have been following it as I'm extremely interested in buying the CA Melomania touch.
Thanks.
For me its not a deal breaker. I had a couple of issues at first but have learned how to get around them. These can be fixed with a software update. The question is whether you can buy buds at a similar price with the same sound quality. From what I can gather you would have to be spending over £200 to achieve this.Hey. This is my first post in this thread but I have been following it as I'm extremely interested in buying the CA Melomania touch.
Thanks.
Thanks.
Since posting that yesterday I had a charging issue! The left seemed to be charging when I put it in the case but when I came to use them in the evening it only had 3%. I agree in that i can't see how that can be fixed from a firmware update, it just seems to be a fit issue.Well, I realized they were not charging so I began doing exactly what @RAINS posted:
"Always remove the earbud from the case that-has connection to the phone first. In my case the left followed by the right. The left will flash white and connect to the phone followed by the right but not shown as connected which is correct. When I finish using them replace them in the case and both flash red for charging. If don’t flash red they are not seated correctly so you mayneed to jiggle as this will be down to any change in bud or tip change."
I will try that for a few days to see how it goes.
It's a common issue. I actually am a poster from head-fi, and people there (including me) were having same issue so I was looking for solutions. That's how I found avforums/this thread. I always thought it was a connection issue, but my opinion has been shifting since yesterday into possibly a charging/case issue, not connection.
I don't think you can fix the charging issue with firmware. I think it is a case issue where charging does not start easily. For instance, I have the Sony wf-1000xm3 and you just throw In earbud, which snaps into place without doing any jiggling around to get the charging to start. Touch rarely starts charging until you push it around & mess with it. It seems to be more for the right earbud than left.
Connection I don't think is the issue. It connects well & easily as long as you take out the paired earbud first. It is a stable connection too.
Yeah I’m gonna try and change my exchange to a refund. Such a shame.Since posting that yesterday I had a charging issue! The left seemed to be charging when I put it in the case but when I came to use them in the evening it only had 3%. I agree in that i can't see how that can be fixed from a firmware update, it just seems to be a fit issue.
I received a prompt and the left earbud still did bot connect albeit pairing. It's now in a box waiting to be returnedI’m waiting for mine to be replaced.
In the communication from CA they state that one earbud will connect and then a prompt (pop up) will appear asking you to pair the other earbud. Has anyone had this?
When mine were working I only connected one earbud and never received a prompt to connect the second earbud?
