Cambridge Audio M1+ remote
Discussion in 'Home Cinema Control & Remote Controls' started by jam_on_shoe, Mar 18, 2006.
  1. jam_on_shoe
    jam_on_shoe
    I've just bought a cambridge audio M1+ remote but I'm having problems programming it. When I'm trying to press the channel up button it only lets me go up one channel and then the button doesn't resond. Is there anyway to program it so it lets you go up multiple channels with multiple presses of the up button.
    Also any advice on the macro button as have no clue how to work it
    Thank you
  2. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    I take it you don't have the instruction leaflet? It clearly describes how to set up macros etc. Your channel up button sounds like it's got a problem as if it's programmed to change the channel you should be able to do multiple changes by multiple presses.
    I've still got one of these remotes and the instructions "somewhere"
    Simon
