Cambridge audio M1 remote..macros...
Discussion in 'Home Cinema Control & Remote Controls' started by jonnyv, Apr 14, 2002.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,320
    48
    +59
    Just decided to program in a macro sequence on my cambridge audio M1 remote Ive had for about a year...The macro sequence is...dvd on,amp on,tv on , av1
    My problem is the tv on function key has to be kept pressed for a couple of seconds before the tv comes on, this happens on the original remote as well...so how do i program the macro to turn on the tv when the key has to be kept pressed ?
    I have tried repeating the tv on function about 4 times in a row within the macro, but dosnt work.
    Any ideas ?
