Cambridge Audio M1 Enhanced - Any Good?
Discussion in 'Home Cinema Control & Remote Controls' started by Ross007, Apr 1, 2003.
  1. Ross007
    Ross007
    Feb 11, 2003
    668
    28
    Bristol
    +40
    This remote is available for 50 notes at RS is it any good? Any feedback would be helpful.
  2. Mickey Mouse
    Mickey Mouse
    Oct 1, 2002
    23
    Buckinghamshire
    Hi there
    Had one of these a while ago and they are fine as long as you don't have more than 8 pieces of kit!! I found that I soon used up all of the buttons and have now replaced it with a sony AV3000 - much better.
    If budget is a constraint then 50 notes will not buy anything much better.
    Hope this helps? :hiya:
