Cambridge Audio DVD79 - how good is it at playing music CDs?
Discussion in 'Blu-ray & DVD Players & Recorders' started by HTdude12, Aug 20, 2005.
  1. HTdude12
    HTdude12
    Anybody out there with a DVD79 unit? - If so, would you be kind enough and answer a few questions:
    How good is the playback quality of music CDs?
    Can it match a dedicated CDP such as Azur 540C or NAD C521 BEE in that regard?
    Also, does the DVD79 suffer from lip-sync issue via S-Video and Analogue outputs?
    *Since both DVD77 and DVD79 feature the same DACs, I suppose comments of those with DVD77 are welcome as well...
    TIA!
  2. HTdude12
    HTdude12
    Anyone? :lease:
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    I had the DVD79 for a short while, didn't get far as testing CD capability which I suspect would be competent but not as good as a decent CD player.
    What put me off was the poor quality of DVD pic via component. Never tried the DVI, which I believe is better - but have read lots about the lip sync probs with DVI.
    Also note - no prog scan with component, only with the DVI..PJ :)
  4. HTdude12
    HTdude12
    Thanks,
    Is it correct to assume that since 540D and both DVD79/DVD77 feature the same Crystal CS4360 DAC, their performance in CD playback is comparable?
    :rolleyes:
  5. Bolf
    Bolf
    Jul 22, 2005
    398
    The Deepings
    +37
    The 540D has a slightly better Cd Transport i believe.
  6. Spacedog
    Spacedog
    In fact i read a post from a Guru at the CA forum and he assured the DVD79 is definitely a loss in terms of Audio Quality. Guess it's the price to pay for that DVI out ;) (a price far too high IMO...). And careful because the DVI out is NOT HDCP compliant! (as confirmed by the Guru also).
    I own a 540D myself and i must say the audio quality is simply amazing! :thumbsup:
  7. HTdude12
    HTdude12
  8. Spacedog
    Spacedog
    Precisely ;)
