cambridge audio dvd59 connected panny 6
Discussion in 'Plasma TVs Forum' started by iwilliams, May 31, 2004.
  1. iwilliams
    iwilliams
    :hiya:
    Anyone know if this is a good player for £150
    I have a panny 6 series plasma and up until today been using a pie 626 dvd player.
    I brought this cambridge audio player today because the guy said
    PScan was really good and I would be able to see the difference.
    So far I cant really.
    Also does anyone know why the screen is letter box and also saying NTSC in the setup menu, I cant select PAL
  2. Ianc
    Ianc
    I bought one of these - and tried all my DVD's on it - switching between interlace and p-scan on my PE30 ... not a jot of difference .
    I also used decent quality component vs the scart and couldnt tell a differnece there either so i might be 'video-blind' and should swap my PE30 for a 14" yamagothciwatchi tv.
    So i ended up taking it back and getting an all -in-one bundle panasonic which looks just the same to me ;-).
    Ive just seen on another thread that the 6-series pannys are meant to have 'good' de-interlacer inside them which I guess would explain why I couldnt see the difference - but guys iwth other plasma's can...
