Cambridge Audio DV57
Discussion in 'Blu-ray & DVD Players & Recorders' started by SiCotty, Jun 3, 2003.
  1. SiCotty
    SiCotty
    All,
    Just got hold of the DV57 player from Cambridge Audio (From Richer Sounds). I got the player because of the PAL and NTSC prog scan. I have got it to play NTSC discs with Prog Scan but the player jumps down to NTSC when playing a PAL disc. This can be best seen on discs such as Toy Story which is very high quality and vertical lines becomes jagged.
    Has anybody else seen this problem with this particular player. NTSC discs look superb but the PAL disc you can tell have something missing.
    Si
  2. Captain chaos
    Captain chaos
    I have heard the CA 57 is a pile of poo.
