Cambridge Audio AZUR 540A? or NAD?
Discussion in 'AV Receivers & Amplifiers' started by chundle, Jul 25, 2005.
  1. chundle
    chundle
    hi all
    what is the general opinion on the Cambridge Audio AZUR 540A? for that price is there something i should consider instead?
    and i would want to get the phono pre-amp -- at richer sounds (linked here:
    http://ws3.richersounds.com/showproduct/CAMB-PM01 ) it shows a picture that looks like it's bare -- does this go inside the amp and is it user-installable? what's it like in anyone's experience? only £20...
    now, i don't have the budget for it, but i'd be interested to know would i get a whole lot more by going for Nad C352 ? and as an alternative, how would the Nad C320 BEE compare which is within my budget....?
    any pointers gratefully accepted....
  2. sennen
    sennen
    Nov 2, 2004
    103
    +6
    Sound-wise, I found the CA 540A a good amp. It was certainly comparable to the NAD I had previously (sorry, can't remember model number, but it was approx 250 quid 8+ years ago!) CA and NAD do sound quite different, and I have to say I preferred the NAD over the CA, but there wasn't much in it and I got used to the CA very quickly. I used B&W 601 speakers with both amps.
    Reliability-wise, I had to return my CA 540A twice in its first 6 months. However, I know two people who have this amp and have had no problems. The NAD lasted almost 8 years before it started to break down.
  3. chundle
    chundle
    "CA and NAD do sound quite different"
    can you elaborate?
    thanks for your comments...
  4. sennen
    sennen
    Nov 2, 2004
    103
    +6
    For me, the NAD felt warm, smooth, kind of restrained - but with plenty of detail. The CA, while still very good - you should understand, felt a bit harsher, with more prominent bass, and seemed less kind to poor recordings/sources (e.g. mp3s or DTV radio channels).
    Note also that the NAD I had was a bit less powerful than the CA.
  5. milpai
    milpai
    Mar 30, 2005
    23
    I own the NAD C352 and am pretty impressed by the music it makes. You will need to compare it with the other amp you mentiones. I have no idea about it. But the C352 has enough warmth and power to get the most out of your speakers. I use the Marantz SA8260 with this amp and the outcome is smooth and wonderful.
