Cambridge Audio AV 540R for Music?
Discussion in 'AV Receivers & Amplifiers' started by Falp, Jun 14, 2004.
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    How does it behave?
    Specially in Stereo!
    Compared to similar priced models, like Marantz, NAD and Denon?
  2. europop1978
    europop1978
    I can't tell you how it compares to those other brands, but I'm very happy with mine.. it has taken my music listening to a new level.
  3. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Didn't you compare before you buy?
    Does it get too hot?
  4. europop1978
    europop1978
    I didn't compare, partly because I was so happy with the 540R's sound, and partly because disconnecting and reconnecting an A/V receiver is a long, arduous task the way my system is setup, and as I don't drive going back and forth to RS isn't that easy.
    It does get very hot, but I have just about enough space around it.
  5. vanne d'air
    vanne d'air
    I have a cambridge since 3 months and I am globally happy. Oh there are a few little defaults but it is a good machine with soft sound, plaisant and power enough to do music and home theather in 45 m². I have the couple Cambridge audio azur 540R - 540D in association with wharfedale pacific evolution 30, center. Before, it was an onkyo and oud Bose 401. Now, it s completely diffrent sound but very exciting.
    Sorry for my bad english
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Can you tell which little defaults are those?
    Does it get hot?
  7. vanne d'air
    vanne d'air
    I Think that in UK the little different bug have to be eliminate. In analogic connection, you have a little "clic" between the tracks on cd reading. and a message appears on the display of the reveiver : "unlock".
    With the remote, you must change source by source to find the right source. dvd,video1,video2,tuner,cd,...thus many clic on the remote....
  8. simonhome
    simonhome
    It spanks my Marantz SR5300's arse in stereo and has a much cleaner sound in DD DTS formats. Voices are more audible and less muddy. I used to have an Arcam amp and this is right up there with it for stereo (compared to the Marantz). :smashin:
