Cambridge Audio Amps x 2
Discussion in 'Hi-Fi Stereo Systems & Separates' started by higenbs1, Aug 28, 2003.
  1. higenbs1
    higenbs1
    Aug 16, 2002
    460
    +11
    Help - I'm doing a wedding on the cheap next weekend. I'm borrowing 2 Cambridge Audio A3 amps to drive 2 sets of speakers in 2 different locations. As the mixer has only one line out, is it possible to daisy-chain the two amps together using the Rec Out sockets, as I can't see that there are any pre-out sockets on the rear panel. I think Rec Out is usually used for MiniDisc connections. Will the volume on the first amp have any bearing on the second amp?
  2. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    Couldn't you just buy a socket doubler and put that over the mixer output and then send one set of cables to each amp. So have a plug over the L & R so that you have 2 L outputs and 2 R outputs?
    A couple of quid each from Maplins.
    It's not exactly an exciting solution but it would do the job?
    Steff
