Cambridge Audio 640T - 6kHz background noise in FM
Discussion in 'Music Streamers' started by apy, Mar 15, 2006.
  1. apy
    apy
    I just bought a new 640T tuner. It's a nice unit, well designed and well built, and the DAB sounds as good as DAB ever does.
    But ... in FM mode there's a constant and distracting 6kHz background tone. A quick Google search shows that this problem has come up before.
    So my question is: do all models suffer from the same flaw? Is it worth trying to exchange for another 640T, or better to go for a different tuner altogether? It would be a shame, given the quality of the rest of the unit, but that 6kHz whistling is very annoying...
  2. kevin marshall
    kevin marshall
    I tried A Cambridge 640 and had the same problems with FM in the shop,but I wasn,t sure if it was the crap aerial. I then tried the DAB500 alas with no Fm but bought one and it really is great to listen to
  3. apy
    apy
    Thanks, Kevin. It doesn't seem to be the antenna; the signal is at 100% strength and runs my old tuner OK. Well, not quite true. It's normally OK, but there's sometimes interference from neighbouring flats which has ruined several recordings, so I thought DAB would provide a backup source for off-days like that. But I still aim to make most recordings from FM, if I can get rid of the background whistling. I'll see if they can exchange mine for another 640, and hope it's not a design fault. But I have a nasty feeling it may be, if you found the same thing.
  4. Anorak East
    Anorak East
    Mar 26, 2006
    4
    3
    Sounds to me like synthesiser breakthrough - I have a Philips tv/radio combo in the bedroom which suffers from this, on FM radio. I got a replacement and it's the same. Irritating on headphones, especially on quieter stations like BBC R3 and 4, but tolerable on highly compressed music stations.
    I also have a couple of digital-tuning portable radios which exhibit the same problem, so I think it's all down to quality of design. If I were you I would try a different model altogether.
