N
nmckearn
I just did a software upgrade for the Azure 640H Music Server...The sequence is:
1. Insert CD and Start upgrade
2. Upgrade finishes, remove CD
3. Restart Server
My wife managed to intervene before the CD was removed and restarted the machine. Now when I switch it on, I get a welcome screen and nothing else and I can't open the CD tray. Is it
a) the server is trying to read from the CD and gets stuck?
b) the upgrade didn't work?
Is there anyway I can fix it either way? I've tried Cambridge Audio's useless web-site and get no response from them or Richer Sounds. So if someone can help......
3. Restart Server
