Cambridge Audio 540R or Denon AVR-1905 or ...?
Discussion in 'AV Receivers & Amplifiers' started by Fatman, Nov 18, 2004.
Tags:
  1. Fatman
    Fatman
    Apr 4, 2004
    125
    16
    I'm looking for a <£300 AV amp principally for DVDs. It must have front L/R preouts (for output to my existing HiFi amp and speakers) and would ideally have a full set of preouts. The 540R and AVR-1905 seem to fit the bill. Which is the more respected device? What alternative models have I perhaps overlooked?
    thanks!
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    The Denon is well built and easier to use. IMO the Cambridge sounds better but it is a bit of a mule to use. Up to you what you value in a product I guess :).
  3. Fatman
    Fatman
    Apr 4, 2004
    125
    16
    What about the Pioneer VSX-D814 or the Marantz SR4400?
  4. Ovation
    Ovation
    For sound, I'd go with the Cambridge (though its user interface is not as intuitive as the Denon products I've had). The Marantz might be a nice alternative, not familiar with the Pioneer in question.
    my (subjective ranking)
    Cambridge
    Marantz
    Denon
    Pioneer
  5. reservoir51
    reservoir51
    Just a short note to relate my experience with the Cambridge Audio 540R. I was rather disappointed with it, both in stereo and multichannel modes. I exchanged it for a Yamaha RX-V650 (£320) which completely blew the Cambridge out of the water in all respects. I've since exchanged the RX-V650 for the Yamaha DSP-AX750 (£400) with even better results. I think the Cambridge's musical performance has been over-rated, and its multichannel performance is only mediocre at best - certainly nothing to write home about. If you find yourself edging towards the Cambridge, I'd urge you to demo the Yamaha RX-V650 (or the DSP-AX750 if you're willing to spend a little bit more).
    reservoir51
  6. Sly Fly
    Sly Fly
    Nov 23, 2004
    1,995
    116
    +719
    Don't mean to hijack this thread, but I have a question along similar lines that may help Fatman as well -
    I'm also looking for an AV receiver that's under the £300 mark. I think I've settled on the Marantz SR-5400 that I can get at £269. The reviews say it is very good for music sound and just as good for cinema sound. Like Fatman, I will be using it for 80% films, perhaps more.
    Is there a better system I should be looking at considering I will be using it mostly for DVD's?
    Fatman - Not sure if it has those pre-outs you want but I know where you can get a .pdf file of the kit which will show you.
  7. Fatman
    Fatman
    Apr 4, 2004
    125
    16
    I think that all of the above four (540R, AVR-1905, VSX-D814 and SR4400) all have full pre-outs. I've subsequently seen the Yamaha RX-V640 for £250 at Richer Sounds, which also has pre-outs. By the way, my use would be pretty much 100% movies! I reckon I'll go for either the Cambridge or the Denon.
  8. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    Sly Fly - you can get the 5400SE from Peter Tyson for a similar price - it's their inhouse 'tuned' version where they check all the component tolerances and upgrade a few parts (I think - I'm not an expert). Probably worth a look.
    Ian
  9. Sly Fly
    Sly Fly
    Nov 23, 2004
    1,995
    116
    +719
    Cheers - I'll give them a try. (Would that be the OSE version?)
    I'm also now cut between that and the Denon 1905, although I can't seem to find a review - ANWHERE - for that particular machine. :rolleyes:
  10. Garrett
    Garrett
    Apr 21, 2001
    40,228
    2
    167
    The best thief you’ll never see.
    +6,658
    Which macine do you need a review for? There is one here for the 5400
  11. Sly Fly
    Sly Fly
    Nov 23, 2004
    1,995
    116
    +719
    The Denon 1905. It's not on the HCChoice website, and a Google search didn't provide any either. Would be MOST obliged if you could point one out.
    Saying that, I'm currently trawling this fantastic website and mostly everyone has said it's a good piece of kit. After days of immersing myself in the wonders (and horrors) of Home Cinema, I think I've narrowed my AV Receiver choices to :
    Denon 1905 (£224)
    Sony 795 (£216) (have to get one that doesn't hiss :D )
    Marantz SR-5400 (£270)
    Yamaha RX-V640
    coupled with either
    Mission FS1's 6.1 (£400 inc. stands)
    Celestion AVP305 (£300)
    Mordaunt Short Premiere (£340ish)
  12. Garrett
    Garrett
    Apr 21, 2001
    40,228
    2
    167
    +6,658
    If you PM me you e-mail address I will try and send you one for the 1905.
  13. Sly Fly
    Sly Fly
    Nov 23, 2004
    1,995
    116
    +719
    Cheers mate, you've just made my mind up. Denon 1905 here I come. :D :thumbsup:
    Fatman - I have sent you a PRV. I'll send the review on to you.
    Garrett - what speakers are you using if you don't mind me asking?
  14. Garrett
    Garrett
    Apr 21, 2001
    40,228
    2
    167
    +6,658
    A bit of a miss match now. I have Castle Harlech front, Mission centre (at the time matched my mission 763’s) and Yamaha rear. I may get some new rear or surround and get them to match. The mission center is still good and what I thought was too, too bight before with the yammy prologic only, is now a low more mellow.
  15. Sly Fly
    Sly Fly
    Nov 23, 2004
    1,995
    116
    +719
    I see. You won't mind if I don't follow suit on your speaker choice(s) then. :D
    MS Prem's v Celes AVP305 for me.
  16. Garrett
    Garrett
    Apr 21, 2001
    40,228
    2
    167
    +6,658
    Bet you’d like my Castle Harlech though. :laugh:
    Let me know how you go on with the 1905 and what I take is less off a mix bag of speakers. ;)
