Cambridge 540R
Discussion in 'AV Receivers & Amplifiers' started by Monkey Alan, Aug 10, 2005.
  1. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    628
    +39
    Anyone know if you can turn the volume up on just the centre speaker, when using Dolby Digital the talking seens very quite and if I turn the master volume up it makes the other 4 speakers too loud. Hope someone can help, thanks.
  2. roversd1
    roversd1
    hit the 'test tone' button on the remote and use the up down keys to adjust
  3. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    628
    +39
  4. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Get a Sound Preasure Level meter and level them all out.
  5. alphabet
    alphabet
    You can also change the sound levels of the individual channels on the fly. Press Channel Select, select the speaker which level you want to change and use +/- keys to adjust the level.
  6. roversd1
    roversd1
    I've got one and couldnt even remember that bit.... :eek: :rotfl: :rotfl:
