cambidge audio azur 540r +guitar
Discussion in 'AV Receivers & Amplifiers' started by systemsdead, Mar 16, 2006.
  1. systemsdead
    systemsdead
    Jan 19, 2005
    12,159
    grimsby,canada
    +7,981
    i am just wondering if it is possible to attach a electric guitar and a acoustic guitar to this amp,just to mess about with,as any body done it or now if it can be done safely,cheers for now
  2. systemsdead
    systemsdead
    Jan 19, 2005
    12,159
    grimsby,canada
    +7,981
  3. rhino2k
    rhino2k
    Oct 20, 2005
    6,077
    +1,283
    i cant see any reason why not, as long as you can connect it :)
    you wont blow it up, unless you get carried away playing jimi hendrix :D
  4. Gary_W
    Gary_W
    Jun 6, 2005
    450
    +21
    Not a good idea at all.
    You need a preamp of some kind to go between the guitar and this amplifier, otherwise you will have an impedence mismatch. Serious damage is unlikely, but it will sound rotten.
    A Line 6 Pod, Behringer V-Amp, Boss GTwhatever will all act as a guitar preamp and allow you to use the 540 line inputs.
    Gary
  5. rhino2k
    rhino2k
    Oct 20, 2005
    6,077
    +1,283
    shows how much i know about guitars :D
  6. fritter
    fritter
    Mar 16, 2006
    don't know if you know or care about this, but you should check out guitar rig by native instruments - you can plug your guitar straight into your pc's soundcard (I use a preamp, but it doesn't really make much difference if I connect directly to my cheapish audigy 2 zx). You can also plug directly into the supplied pedal (which connects via usb). Either way, you can then use your soundcards output to your receiver, or you can just forget about the receiver and use the pc's speakers if it's a decent setup.
    http://www.native-instruments.com/index.php?guitarrig2_us# has a nice demo movie :D
