Cam to PC - USB or Firewire?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Roger G Cam, Jun 4, 2004.
  1. Roger G Cam
    Roger G Cam
    Okay - I expect some of you are going to look at the title on this thread and sigh. Bear with me - I am at the beginning here.
    Camcorder to PC - with USB - I get an error on 1394 Port.
    I think that I can only connect using a Firewire (which is what the 1394 port is all about) if I have Camcorder set to VTR. In other words if I want moving pictures it isn't going to work using USB.
    Am I correct? Firewire card needed in the PC?
    Roger
  2. Brian110507
    Brian110507
