CAM the same as PCMCIA
Discussion in 'LCD & LED LCD TVs Forum' started by bledd, Oct 18, 2005.
Tags:
  1. bledd
    bledd
    Aug 25, 2005
    58
    +5
    I am interested in a tv which has a CAM slot, is this the same as a pcmcia slot?
    thanks
  2. mitor
    mitor
    Mar 2, 2005
    1,255
    weston super mud
    +117
    Well mostly!
    PCMCIA is the actual form factor of the card (It's old PC terminology) and they are found on most laptops
    CAM, as I understand it refers to "conditional access module" or some such goobledegook.
    Both terms are sort of interchangable, mind you the Pio plasmas have PCMCIA slots, but they're used for a CFII reader, might be better looking for "top up tv" compatible if that's what you're after.
  3. bledd
    bledd
    Aug 25, 2005
    58
    +5
    Well i am looking at the toshiba 32wlt58 which in the operators manual indicates that it has a CAM slot. I have a PCMCIA memory card reader and was wondering if it would be compatable with the tv.
    thanks
  4. mitor
    mitor
    Mar 2, 2005
    1,255
    weston super mud
    +117
    ahhh, I assumed you were trying to get top up tv.
    No experience of the tosh, but I would say highly unlikely.
    Almost all PCMCIA slots in tv's are for conditional access, the PCMCIA card would slot in but do nothing.
    the only TV's i know with in-buiult .jpg readers are..
    the pioneer xde plasma (which uses a PCMCIA slot)
    some panasonic's have an SD card slot, as do a few "no name" makes.
    hope this helps
  5. bledd
    bledd
    Aug 25, 2005
    58
    +5
    thanks
