C
c36-williams
Hi all,
I Have just received the 8GB version of the samsung YP-T10 today and have noticed a slighly annoying issue with the end of tracks.
I seem to be getting this slightly slushy interference sound at the very end of each track. But this only happens when I am using the DNSe options...has anybody else noticed this? I find it especially noticeable when using the user settings with the bass up a little?
Perhpas I am just being fussy..I probably am but was just wondering if this is some kind of minor fault or a common problem..perhaps to do with the current firmware (v1.55) which I updated to almost as soon as I opened it up btw..lol...wish I have checked it with the older firmware now
Anyway, any ideas would be helpful
PS: Any sound setting suggestions for the EQ etc would be useful as I have no idea what I am doing with that?
UPDATE:
Just noticed that the player does this whenever the sound level on the track dips to silence or near silence quite irritating actually if it does it at silent points as well. I also just did a quick comparison with someones YP-K3 player and that did it as well, although not as badly and easily overlooked...think this must be some kind of problem to do with the DNSe processign then
UPDATE:
