Calling all Yamaha DSP-AX620 Owners
Discussion in 'AV Receivers & Amplifiers' started by TomHomewood, Mar 14, 2006.
Tags:
  1. TomHomewood
    TomHomewood
    Hi everyone,
    I have just bought a second hand dsp-ax620, and have found it to be excellent so far.
    However, I have a graphic equalizer which I used in my old system, and cannot work out how to use it with the new amp. The amp is meant to have 3 tape loops, but I cannot get the amp to use the CD as the source, and send the signal through one of the loops (in this case the eq), and back to the amp, so that the eq has an effect on the sound.
    At the moment, the only option I have is to put the eq in-between the CD player and the amp, but this means other sources (tuner) cannot be used with the eq.
    Any ideas? Is this even possible? The manual is not clear on this subject.
    I hope this all makes sense.
    Thanks,
    T
