calling all Sony KV36FS76 owners please
Discussion in 'General TV Discussions Forum' started by MackemX, May 6, 2003.
  1. MackemX
    MackemX
    Dec 9, 2002
    175
    16
    I need to know whether the Ignore Errors is ON or OFF by default with the KV36FS76
    to remind you how to get into Service Menu, turn off TV by main button
    press and hold the Prog up & Prog down buttons on top of TV and push the power button in holding the 2 channel buttons until you see TT on the TV
    press Menu twice to get to Service Menu
    then select Monitoring then Error Monitor and it will show what it is set to
    cheers
  2. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    Been playing ;)
    I think from memory its ON, but ill check for you tomorrow.
    Is it possible to set convergence perfect on the FS76? If you look very closely at white text in teletext do you see other colours around the edges? Ive been messing for about 3 hours but its very difficult using only the ntl menus. Must get a DVD player and THX disc!
    Plus do you hear any burbling interference through the left speaker at 2 bars volume? Its not the hiss I'm on about. Its only coming through the left middle speaker.
  3. MackemX
    MackemX
    Dec 9, 2002
    175
    16
  4. MackemX
    MackemX
    Dec 9, 2002
    175
    16
    surely someone has this TV?
    please help :)
  5. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    This is how it looks:
    Ignore Errors OFF ON OFF
    The orange is a continuous yellow bar BTW.
  6. MackemX
    MackemX
    Dec 9, 2002
    175
    16
    cheers :)
    I've just been to Curry's to find out
    panicking a bit, mine was ON, but I'm sure it was off
  7. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    I doubt it matters since all it does is build up a log of errors below.
    Can anyone answer my convergence and speaker question?
  8. MackemX
    MackemX
    Dec 9, 2002
    175
    16
    WSH, have you not got a TV out on your PC?
    you can create your own Template
    purple dots/lines on a black background shows up any weak spots
    that's what I used to show TV guy cos during normal viewing it's hard to see from a distance
    do you have a dvd or cd burner?
    I could create a VCD or DVD and email you it use if you want
  9. MackemX
    MackemX
    Dec 9, 2002
    175
    16
    take all your scarts out and see if you still hear the noise
    I posted this in another thread
  10. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    That would be great thanks. I could attach the PC by SVHS lead, so I only need JPEGs.
    [email protected]
    So were you unable to fix it with the menus, so you called a repair guy?
  11. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    Its not the scarts since I have pulled everything out inc. RF in and turned off all the other plug sockets behind. Its like a burbling sound only from the left mid range speaker. Its there on both AV and normal channels.
  12. MackemX
    MackemX
    Dec 9, 2002
    175
    16
    I'lll email them ASAP, got stuff to do cos they are coming within the hour
    I could have adjusted it but I wanted them to do it, but JL are just replacing the damn thing instead of fine tuning it!
    don't matter anyway cos my 2nd tuner had interference and the AV channels also suffered from interference on darker scenes more than other TV's I've seen
  13. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    The second tuner you say had interference. Do you mean you get wavy lines in the right hand side box in picture in picture? If you do, all three sets I had wavy lines.
  14. MackemX
    MackemX
    Dec 9, 2002
    175
    16
    yep thats them, wavy lines on the 2nd tuner when you do PAP
    just got new set setup and it's AWESOME!
    absolutely perfect :clap:
    stuck Ultimate DVD on, and my PC TV out purple gridlines and it's absolutely brilliant
    what an improvement :D
    even the 2nd tuner does not have the wavy lines, just like the one in Currys didnt
    Sky isn't as blocky either!
    why couldn't it be like that in the first place?
    there is the slightest of slight convergence out in a 5cm section on the top middle but I'm talking microns and nothing that is noticable unless you sit with your nose on the screen with the testpage on, but I gues that's be very picky
    hopefully now I've got the one to last
    happiness at last
    :smashin:
  15. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    I connected the pc to the tv and it had the wrong resolution or refresh rate. It had lots of wavy lines. I had the wavy lines on the screen for maybe 20 seconds. I have read up that I could have damaged the TV. Oh dear.
  16. MackemX
    MackemX
    Dec 9, 2002
    175
    16
    what resolution did you output at
    my card only allows 2,
    800x600
    1024x768 (which I use)
    I've sent those pics, have fun :)
  17. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    1024x768, 110Hz not 60Hz as it should be.
  18. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    Thanks fr the email. So does you new set have good convergence at the corners of the screen?
  19. MackemX
    MackemX
    Dec 9, 2002
    175
    16
    nope, it's just about perfect and absolutely brilliant compared to other one
    gives a much sharper picture in the corners with things like small text etc
    chuffed I complained now cos I was worried at getting a naffy set, but this one seems a lot better
    have you tried yours yet?
    I was gonna make a simple mini DVD for people, of around 500kb to burn on a CD that has a few more test screens I used, so they could check their sets using the DVD player instead of PC, cos the DVD fills the screen whereas PC don't
  20. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    The sides are blurred and top right convergence cannot be fixed. Bottom right is fine and left is out. I have spent 2 hours on it with only a slight improvement. This is our third set. I am feeling very depressed. What will JL say if I request a fourth?
    Could you look at white teletext for me and see if you see any colours around the white text in any part of the screen.
    In addition to your JPEGs, I found this program that has a test card in.
    ftp://sunsite.cnlab-switch.ch/mirror/winsite/win95/sysutil/testm-e.zip
