Calling all PC experts
Discussion in 'Desktop & Laptop Computers Forum' started by (GTV)Chris, Aug 10, 2003.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Hi there
    Just a quick pc motherboard question.
    I have recently upgraded mu CPU to an Athlon 2600+ XP chip.
    The only thing is is that my Mobo is seeing it as a 2000+.
    The Mobo is a Gygabyte GA7 VAX and on their website it states it will take up to a 2800+
    Do I have to do anything to rectify this?
    It's not one of those horrid flash type thingies is it?
    I am hoping it may just be a bios setting.
    Best wishes
    Chris
  2. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    just had alook on Gigabyte site what bios have you got as you will need F10 to work correct
    here the link to Gigabyte and your MB
    Boogie man :cool:
  3. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Cheers Bud.
    Hope this goes OK....always a bit nervous upgrading Bios :eek:
    C
  4. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    OK - tried that...
    It says "Chipset not supported"????
    I have emailed Gigabyte to see what I have done to my PC.
    I have a long history of knackering up every PC I have owned :(
    C
  5. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Are you sure you've got the right BIOS downloaded??
    You didn't download the GA-7VRXP by mistake did you??
    Not sure about the 7VAX but my 7VRXP has a backup BIOS in case you "screw" up whilst flashing :)
    Try holding down the INSERT key whilst powering on :)
    Dave
  6. andyw
    andyw
    Probably because you have the FSB (Front side bus set at 100 instead of 133), you can change the setting in the bios, reboot and all will be well
    OR
    There is a jumper on the motherboard that can be set at either 100/133 or 166, read the motherboard manual to see which position corresponds to which FSB speed
    andyw
