Calling all Panasonic PT-AE500 (TH-AE500) Users
Discussion in 'Projectors, Screens & Video Processors' started by Drew2, Sep 11, 2005.
  1. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Hi Folks,
    Just to let you know that Panasonic are now no longer manufacturing replacement bulbs for this machine! :eek: Only 3yrs old and already put on the scrap heap!! :mad:
    So check out your local retailer for their stock situation hopefully there is a stockpile of them and bulbs will be available for many years to come. :rolleyes:
    My bulb is nearly unusable in "cinema" mode - constant brightness flickering, still a good picture on full power but fan noise can be annoying in quieter scenes. I run on full power for about an hour then switch back to cinema which sorts out the flicker for a while. :(
    Total Hrs = 3832 On/Off = 1016 '2000Hr' counter = 1658 Used for 22months.
    Cost of new bulb 26,775 yen - approx 135 quid = 3.5p an hour! :thumbsup:
    Will decide to buy some stock when new bulb arrives - want to see the difference in PQ and brightness, if a big leap then will get a few more otherwise will move PJ to bedroom and upgrade to a newer machine sometime next year. :rolleyes:
