Calling all MXE1 Owners
Discussion in 'Plasma TVs Forum' started by loonatic, Nov 8, 2004.
  1. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Thinking of getting an MXE1, not sure if funds permit a 43" or 50" yet :rolleyes:
    Anyway...what do you guys think of yours ?
    My main issue with all plasma's is the annoying buzz they can/do make...have owned a Pio 433HDE and a Panny 50" PWD6 in the past...how does your MXE1 behave in this regard ?
    I would be feeding mine DVI via my Lumagen ProHDP with Sky+ being input as SDI with my Denon 3910 getting the same SDI treatment soon.
    Anyone had any problems or issues ?
    Would you buy the same thing again if you had the chance ?
    Cheers, Lee
  2. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    641
    +16
    Picture is superb. Better than I was expecting. I have the contrast and brightness turned down at the moment so I know that after the first 200 hours I can tweak and improve this even further. The blacks are also better than I thought they would be and the colours are really vibrant. Even the other half was impressed (though did grumble about the size ;-))
    When fed via an upscaling DVD player or HTPC the dvd quality is wonderful. I'm using a freeview-style Digibox for tuner facilities and the pic is very good. I wasn't expecting a lot TBH since you read so many posts about poor quality TV - and I am feeding it into the plasma via S-video!
    My model has a very very slight buzz which I cannot hear the moment any sound is output (and I'm talking quiet TV-volume sound, not loud movie-volumes). Basically haven't given it a second though - it just impossible to hear unless your room is pin-drop silent and even then I doubt I could hear it unless I was up close.
    I went with the silver model to match the rest of my stuff and the finish is nice.
    If you're going SDI I would say that you'll be very happy.
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It has to be said HDE's are the most consistently noisy units, and of course panasonic 50" have big power supplies and such. The 43MXE is to all intents and puropses silent in my experience. You are welcome to rest your ear on ours. Pioneer's quality control seems very consistent, they are all the same, you don't hear people complaining about them on here do you. Every other plasma in creation has somebody bitching about something or other, but not the MXE-1, it seems to have no enemies. With your setup and knowlege, I am quite certain your picture will be as near to perfect as possible, go for it.
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Thanks for the replies :smashin:
    Did you go for the 43" or 50" Mr Wilby ?
    Just a quick question, perhaps MAW you will know the answer to this one...does the MXE1 have discrete IR codes for power on and power off as the remote only has a toggle button ?
    Any other owners care to make a contribution :thumbsup:
    Cheers, Lee
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Hi Lee, there are discretes available, pioneer haven't chnaged the codes in living memory, I got them from remotecentral.
  6. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    641
    +16
    I have the 50" and love every 1/8th of it ;-)
  7. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Discrete codes are one of the big advantages of going Pioneer IMO... Everything is covered...
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Qualify that, going Pioneer MXE. This does not apply to HDE/XDE models.
  9. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    The 433/503HDE series didn't have discrete control, however the 434/504HDE series does... I don't know about the 435/505XDE series..?
    Xantech do an IR > RS232 converter which would solve the problem on the Panasonic panels (at a cost), although discretes may be available in the 7 series... Has anyone tried yet..?
    MXE series is certainly the best in this respect IMO...
  10. steverb
    steverb
    Jun 11, 2004
    89
    I have had my MXE1 43inch for about 3weeks and the picture is stunning (suppied by Joe). I use the Lumagen Vision HTP from a freeview box, not SDI, and have no complaints. Much better TV than I could have hoped. No noise from the screen that I can detect. Make sure your amp can adjust lip sync - the delay through the Lumagen is about 20ms.
  11. philipb
    philipb
    Mar 6, 2002
    2,034
    63
    Swindon
    +149
    Best display you can buy - simple as that.
    The fan on mine never comes on - so it is completely silent.
  12. creative-av
    creative-av
    Aug 30, 2003
    1,093
    48
    +56
    Hi All,
    I am also looking at buying this screen and wondered what the best price for it is at the moment. Can anyone help?
    Cheers,
    Steve
  13. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    I had a boss in a previous life who said
    "a deal is only a deal when it's a deal".
    We all have a finite amount of money to spend but you should realise that a dealers worth only really comes in to play once you have bought. Who wants to get a great price and then have to spend hours scouring the internet for back up as the dealer is a box shifter. There are a far few dealers here who are a few quid more but who will save you time and trouble with their undoubted expertise. Read this forum for a while and see who POSTS....and you'll work it out.
    Gordon
  14. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    641
    +16
    I would second what Gordon wrote above.
    I've had a lot of success with Joe Ferdinand from www.tmfsolutions.co.uk. Been dead helpful and posts on this site regularly.
  15. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Back on the IR topic, there are workarounds for Panasonic, it's not that bad, and of course many folks will be buying one of Gordon's fine scalers, in which case you never switch inputs on the plasma, just set 1 as default, and 1 as picture in picture,and it's done for life. You only need on and off discretes. So it's a very straight choice between Panasonic and pioneer, and I'm genuinely not convinced in either direction. I would happily own either. In fact I am likely to end up with Panasonic, we have a demo MXE-1, so I will get the other. My business partner is an interior designer, and has to have silver to match her curtains or some such...
  16. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    MAW, wise words as always...
  17. philipb
    philipb
    Mar 6, 2002
    2,034
    63
    Swindon
    +149
    Except - there's only one thing better than a Pioneer 43MXE1 and that's 2 Pioneer 43MXE1s :)
    Gordon is dead right as well of course.
    I have bought plasmas from AV-Sales and Joe, and you won't go wrong with either. Good prices and excellent back-up.
    Had my MXE1 long enough now that calibration is the next step. Gordon, are you coming south for the winter or should I contact a more local guy - I think someone in Bristol does it?
  18. creative-av
    creative-av
    Aug 30, 2003
    1,093
    48
    +56
    All,
    Thanks for the replies. I agree that buying the product at the lowest price doesn't guarentee good service.
    However, reading thru some other posts on the forum there does seem to be a big difference in prices for this screen and as a newbie to the "Which Plasma should I buy" debate I was after some guidance.
    Cheers,
    Steve
  19. philipb
    philipb
    Mar 6, 2002
    2,034
    63
    Swindon
    +149
    Also worth mentioning that some of the low priced suppliers do not include the video board - you pay extra for that whereas Joe and AV-Sales include it. Also make sure the price quoted includes VAT.
  20. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    Yeah - Plasmapoint.co.uk are doing it for £2581 inc. VAT (no extra boards though)... Still rather get it from someone who'll look after me if it goes a bit pear-shaped...
    Also, philipb - do you know who does calibration in teh West (I live in Bath)?
  21. philipb
    philipb
    Mar 6, 2002
    2,034
    63
    Swindon
    +149
    Sulis
    Can't remember, but I think he visits this forum. Gordon knows him I think - Gordon??
  22. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    His name is Piers, Look him up in members list, and drop him an email, unless Gordon fancies another run south. You guys could co-ordinate, make his life easier.
  23. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    I'd also recommend the MXE-1, for all the reasons already stated, including great service from Joe at TMF. It looks great using an RGB-VGA converter, but if you can keep to an all-digital path, it is stunning.
    I tried using an early Lumagen HDP, but found it a bit troublesome. I know there have been many updates since then so its probably sorted out now. At the moment I use my HCPC for pretty much everything (TV, DVD & Xlobby Via Theatertek & some web browsing). I'm over the moon with its performance, and have not seen anything better.
    BTW Simon, I still haven't had a chance to try that judder tester! :blush:
    Rob.
  24. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Hello Rob, you read my mind... Still interested to hear how you get on...
  25. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Thanks Rob...have you had any worries about screen burn at all whilst using the HCPC ?
    I remember hooking up my PC to my 433HDE when I had it for just a short while only to find the Start Menu/Taskbar still displayed when I changed input...turned out it was just a case of image persistance as opposed to actual screen burn but it did put me off using the PC with the HDE.
    The Panny I had for a while seemed much less prone to screen burn.
    I've got a fully functioning HTPC which I use with my PJ which is another reason I am thinking about the MXE1 due to it's FRC features.
    Cheers, Lee
  26. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    Lee,
    I've not had any problems with screen burn , but as you say you can get image persistence, which soon disapears. I've only noticed it a couple of times with the "Cbeebies" logo, :rolleyes: not that I spend too long watching it of course.
    I was very concerned the first time it appeared, but extremely relieved when it was gone the next day, still I try not to leave it on one channel longer than necessary if a logo is used.
    Rob.
  27. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    I was driving past yours two days ago. I'm back down end of month probably. Get in touch via email for dates.
    G
