Calling all MK1 REL Storm owners: how do you stop the hum??
Discussion in 'Subwoofers' started by SilverPenguin7, Aug 19, 2002.
  1. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Have heard that the hum my Storm creates is due to an earthing problem with the unit that many of them suffered from. Does anyone know how to stop this as I have been told there is a way, just not what it is!
  2. Guest
    Mine hummed when I had a long signal lead (low-level). I trimmed it to size (about 1.2M) and the hum disappeared totally. Get all other mains leads well away from it too.
    Mike.
  3. NeilS
    NeilS
    Nov 16, 2001
    215
    Essex
    +8
    Make sure the connecting lead is screened otherwise it'll pick up rf/hum.
    Neil
  4. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Thanks guys, the cable is bloody long. Its the one that was supplied with the sub, which I would imagine is screened?!
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Are you certain your sub cable is connected correctly? I presume you are using the neutrik cable, the yellow wire should go to a black terminal.....
    beyond that i cant help!
    Ad
  6. GJC
    GJC
    Mar 1, 2002
    2,142
    London
    +69
    Buns -
    Think you may have your wires crossed....
    The Mk 1 storm has an XLR plug - the newer ver. have the Neutrik.
    :rolleyes:
    Always worth trimming any excess cable as it will cause problems with other electrical cables - unless all of yours are screened.
    Never coil any cable.
    GJC
  7. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Ahhhhh right.....so that means my storm isnt a mark 1.......
    sorry for butting in in that case!
    Ad
  8. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Damn MK1 not having RCA inputs!
    Hopefully getting my 10m cable that it came with (10m! I ask you!!!) chopped down will help solve the prob. Can't be helping things!
  9. GJC
    GJC
    Mar 1, 2002
    2,142
    London
    +69
    I had a cable made at Sevenoaks HiFi which had XLR to Phono
    This cost a small fortune but I am sure you can get one done for around £60 for 3-5 metres.
    Take your existing 10m cable in and they will trim it and fix a phono plug to the other end. That wont cost much.
    Phono Plug - WBT (brand) around £15
    Shielded Cable £'s upwards or nothing if you use existing.
    Charge for fitting (nothing for me)but should'nt cost a lot.
    GJC
  10. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    They must have seen you coming. I bought a phono to XLR cable from Lektropaks for about £20 and the local TV repairman charged me £4 to resolder it to the correct wiring for an REL
  11. GJC
    GJC
    Mar 1, 2002
    2,142
    London
    +69
    Ian J
    Thats possibly true - (in my younger days aged 21 with money to burn - Those were the days).:devil:
    6 years ago. 10m of High Quality cable (db - I think) £20p/m + £15 for the WBT phono plug.
    GJC
  12. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Sevenoaks quoted me £120 for a cable!! They also told me I would beb etter off looking around! lol
    I got a cable made up from Lektropacks as they are 5 mins from me. However, it was to short (an error on their behalf) so I am taking it back for a refund and just gonna get my 10m cable chopped down to size.
  13. Lowrider
    Lowrider
    I don´t think it is the lenght of the cable, mine worked fine, what I had to do, was to disconnect the earth from the amplifier´s power lead, and the humm was gone...
  14. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Excuse my ignorance here....is that a safe thing to do :confused:
  15. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Unfortunately Lowrider can't answer as he has electrocuted himself.
  16. Member 14718
    Member 14718
    Previously BK Electronics
    Aug 10, 2002
    376
    Essex
    +25
    It should be ok if you only remove the earth from the amplifier (0v Ground ) but should always keep it connected to the front panel as it is a class 1 product
  17. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Hmmmmm not sure I like the sound of this!
    The sub didn't hum when it used to be connected via the speaker terminals though, so why would it do it when connected via rca? Or does it come back to the earth problem again?
    I haven't had a chance to get the cable chopped yet but will do anyway as 10m bunched up cant help!!
    No reply from REL either :(
  18. Lowrider
    Lowrider
    I don´t think it is 100% safe, but if TAG gear doesn´t have ground connection, how dangerous can it be... Anyway, thats the way I have my 4 powers, and no problem so far, cross my fingers... :eek:
  19. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I emailed [email protected] and didn't get an answer as he was away ill. It would seem that although very helpful, no-one reads his emails if he is away.
    There is another techie chap there although I have forgotten his name so why not telephone if you require a quick response.
  20. Member 14718
    Member 14718
    Aug 10, 2002
    376
    Essex
    +25
    That would be Class II double insulated, look for the two squares one inside the other on the back panel. This is made and tested to a more stingent specification
    Just a thought, I have read the other posts and I see you are using the supplied 10M lead which is not screened. Have you tried using a screened lead?
  21. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Is the supplied lead not screened?! That is most likely the reason then I would hope. Long lead and un-screened.
    I will give REL a call on tuesday and see if they can shed any light on the whole thing.
  22. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Be VERY careful about loosing the earth connection on the mains input. It is all down to how a piece of equipment has been designed. The Tag HAS been designed to work without it (best in my view). I would recommend NO ONE makes this mod unless they have checked with the supplier of the equipment first. You are asking for big trouble.
