Calling all BFD users, help needed please
Discussion in 'Subwoofers' started by ShinObiWAN, Jun 10, 2004.
  1. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    I'm currently stumped on how to go about BFD'ing 2 subs in my setup.
    I'm using the DSP1124P so I can in fact do this without problem but can somebody offer me a process by which I do this.
    Is it simply a case of BFD'ing each one seperately or do I do both together?
    I use a Real Time Analyser with the Behringer ECM8000 mic rather than the SPL meter and Excel spreadsheet method if that makes any difference.
  2. Ettepet
    Ettepet
    Feb 7, 2003
    738
    The Netherlands
    +19
    Hi ShinObiWAN, nice stuff you have there, and a tough assignment.. ;)
    I would try to put the subs first in the recommended places you read about on the net, "middle left wall & middle right wall" among others. I hope that one of the subs has a fully (0-180 degrees) variable phase dial, as this will help a lot.
    For more read these topics/links:
    http://www.avforums.com/forums/showthread.php?s=&threadid=65603&perpage=15&pagenumber=4
    http://www.snapbug.ws/brucekreviewofbfd.htm
    I skipped through the links a bit, and I see people there stack their subs, I don't know if that's an option for you.
  3. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    Yep they have the variable phase control so hopefully that will make it little more simple.
    To be honest I knew it would be pain but I believe that 2 subs are worth the effort if done correctly.
  4. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,500
    Newbury
    +173
    ShinObiWAN - where are your subs in your room? Are they both at the front, left and right, one front, one rear?
  5. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    Hi Chris,
    They are positioned about 2 feet in front of the mains against the left and right walls.
  6. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,500
    Newbury
    +173
    ok, i'd be inclined to do both at the same time then. you might want to consider using a splitter and use one BFD channel just for the setup - then you can copy the settings from channel 1 to channel 2 for normal operation, just might make setup easier if you only have to alter one channel for both subs.
