Calling all AV geeks - help identify my PJ screen
Discussion in 'Projectors, Screens & Video Processors' started by GavT, Jan 20, 2008.
  1. GavT
    GavT
    Dec 20, 2004
    841
    Colchester
    +33
    Welcome to this week's game of 'ID my PJ Screen' :D
    I bought a screen off a friend the other month and have had no luck identifying the manufacturer. My friend bought it in Germany but cannot remember where. Some details:
    - electric with up / stop / down buttons
    - there was a remote control but my friend has misplaced it
    - 286 cm long in a hexagonal white case
    - 16:9 aspect ratio
    - it appears to have end stops but either they are not calibrated or they are knackered
    - the only distinguishing feature, I think, is the end caps on the case are screwed in with fairly cheap and nasty fixings.
    - the case is unbranded and the circuit board on the control box is unmarked
    - the only :rolleyes: branding is on the mains cable from the control box to the screen, it says L&A
    I know this is all a bit vague, so I guess you see my problem. If anyone can give some clues on how I can find out who made this, please let me know.
    Primarily I am after the IR codes and the user guide on how to adjust the end stops.
    Cheers,
    Gav
  2. AV Nik
    AV Nik
    Jul 11, 2006
    581
    46
    +100
    Would be easier if we could see a picture.
    Is this possible?
  3. IanD
    IanD
    Jun 27, 2002
    122
    Brisbane
    +8
    Gav, from your description it sounds very much like it could be a screen from HCSV. look here http://www.hcsv.co.uk/shop/catalog/remote-screens-c-54_66.html If you have a universal remote, I am sure someone will be able to supply you with the correct codes. I have the codes for a Pronto RU980 if they will help. Regards, Ian.
  4. sapper
    sapper
    Jul 20, 2000
    2,258
    Southgate, North London
    +145
    What are these screens like? I am interested purely becasue of the case of the screen size being 9 cm by 9 cm....
    Adrian
  5. IanD
    IanD
    Jun 27, 2002
    122
    Brisbane
    +8
  6. cybrey
    cybrey
    Apr 21, 2005
    572
    +64
    Just a slight correction HCSV are a distributer of the screens in the uk (one of many), Exculsiv-home Cine-Screen ( based in Germany) are the manafactures, but I agree it sounds like an HCSV / Exculsiv screen.
    End stops are like most screens, two screws one adjust stop at the top other alters screen at the bottom.
    I no longer have the codes for the IR remote as I didn't keep the screen for very long. The guy that runs HCSV is pretty nice he may be able to supply you with the pronto codes if you talk to him nicely :)
  7. GavT
    GavT
    Dec 20, 2004
    841
    Colchester
    +33
    Thanks for the info chaps, a pretty good guess. :smashin:
    Looking at the Exclusiv website these screens are certainly very similar however mine does not have the Ethernet port nor IR receiver in the casing.
    However, does anyone know if Exclusiv did other models a few years ago? I wonder if I've got one of their pre-Ethernet models.
    I'll try and post a pic.
  8. GavT
    GavT
    Dec 20, 2004
    841
    Colchester
    +33
    Hi Ian,
    That's great :thumbsup: I have a ProntoPro RU970. Is it possible to PM the codes?
    Cheers,
    Gav
  9. GavT
    GavT
    Dec 20, 2004
    841
    Colchester
    +33
    Okey-dokey, here's some piccies - any help?
  10. cybrey
    cybrey
    Apr 21, 2005
    572
    +64
    Does look like a Exclusiv v3/4 screen.
    The ethernet port and revised remote were added to the v5 screens ( currently on sale).
  11. GavT
    GavT
    Dec 20, 2004
    841
    Colchester
    +33
    Well cybrey I think you have won the prize for identifying my PJ screen :thumbsup: - doing a bit of surfing and it is almostly definately a Cinescreen although not sure which version.
    You can be proud of your projector screen prowess :clap:
    Again, a good example of the quality AVForums and its members.
    Thanks all,
    Gav
  12. cybrey
    cybrey
    Apr 21, 2005
    572
    +64
    Thanks for the thanks, although to be fair IanD actually suggested it first :)
