Question Calling all Arcam A39(possibly A29 & A19)
Discussion in 'AV Receivers & Amplifiers' started by b36lbx, Jan 16, 2017.
Tags:
  1. b36lbx
    b36lbx
    Jan 5, 2017
    40
    Cwmbran, South Wales, UK
    Hi all, could be a noob question, but just wanted to check.
    My A39 balance control does not completely shut off one channel and I'm not sure if that's normal or not. For example if I push the balance to L12(max left), the left channel is louder than the right but the right is still pushing sound. Exactly the same thing happens if the balance is pushed to right, right channel is louder but it doesn't completely shut off the left channel.
    Thanks.
  2. sosen13
    sosen13
    Feb 24, 2014
    946
    Peterborough, United Kingdom
    +90
    same thing is happening with my a39 so I believe it has to be like that , however a19 which I had earlier shut off one channel completely
    have you found out anything more about it? thx
