callibrating cineza
Discussion in 'Projectors, Screens & Video Processors' started by bob, Jun 23, 2002.
  1. bob
    bob
    I have tweeked the thing quite a lot but I wonder if somebody else done that with good results.I have succesfully got to the service menu and adjusted colours.On my PC did lot of stuff but I can not simply get rid of the pixelation.If it is out of focus -yes it helps but you can't watch anything.So, what do I do next.
    Should I get a filter?(which one)
    Any advice about the service menu?
    Has anybody here proper set up?
    How can I get a little smoother picture?
    Any help appreciated
  2. Guest
    Earlier, someone posted that the Cineza now comes with a filter from Sony. I would call Sony up and inquire about it. As far as the pixel problem- a lot of it depends on the video card in your pc. Any current ATI card is the best.
    Scott
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    You can't do much about the pixel gaps on a fixed panel projector. A de-interlaced image (like that from a HCPC) helps reduce the motion artifacts which tend to show up the panel structure.
    Your options now are either to project a smaller image (or sit further away), change projector to something with a better pixel pitch (smaller gaps), or investigate add-on lenses like those from Cygnus. They claimed to have a lens that "multiplied" the pixels for a smoother image. Try searching the American AVS Forum for more info.
    Regards
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Brundelfly?
