Call of Duty widescreen possible?
Discussion in 'PC Gaming & Rigs' started by cameronl, Aug 6, 2004.
  1. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    hi there, does anyone know if its possible to play call of duty on widescreen 848*480?
    and are there any uk clans around that are good for not so great players?
    thanks
    CaM
  2. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    I tried to play Call Of Duty along with DOD on my 42" W/S plasma with not much joy.
    Widescreen was ok but the combination of resolution and large screen really made it unplayable.
    Console games designed to work on a normal telly at lower res work and look ok though.
    What size of screen are you using?
    Been in a few Clans over the years and found unless their actual friends, Clans are more hassle than their worth IMO. Too much in house bickering and arguing and internal politics. Maybe i've just been unlucky.
    Panic
  3. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    ok, thanks for the clan update - I'll pass on that then :)
    I was displaying it on a 5 foot screen via a Sim2 DMF - it looked ok at 800*600 but i really wanted it at 848*480 to fill the widescreen.
    thanks
    CaM
  4. betamac
    betamac
    Download powerstrip
    it has the exact resolution of plasmas i used it for my Panny PWD6 and call of duty and it looks great very crisp, even windows desktop looks looks great and is fully useable
  5. wolfeh
    wolfeh
    Feb 21, 2003
    500
    Ramsgate, Kent
    +10
    Taken from another web site
    Just change the height and width values to what suits you and away you go :)
    Ive had Call of Duty running at 1280*720 over my z2 and it really was something to behold :smashin:
  6. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    oh cool! thats great - thanks heeps :)
    CaM
  7. wolfeh
    wolfeh
    Feb 21, 2003
    500
    Ramsgate, Kent
    +10
    Just make sure you make the config file read only after you have modified it...
    Or you can forget like I did and spend ages wondering what went wrong :suicide:
  8. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    No idea you could do that with a plasma screen. I'll give it a go as well.Sorry if i mislead you at all Cameron.
    Panic
