Call of duty fatal error problem
Discussion in 'PC Gaming & Rigs' started by iZombine, Mar 26, 2005.
  1. iZombine
    iZombine
    Jan 21, 2005
    870
    28
    +33
    I've just installed Call of Duty but when i try and play it i get this message
    Fatal Error
    Configure.csv not found
    C:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files)
    C:\PROGRA~1\CALLOF~1\main\pak2.pk3 (694 files)
    C:\PROGRA~1\CALLOF~1\main\pak1.pk3 (2642 files)
    C:\PROGRA~1\CALLOF~1/main
    C:\PROGRA~1\CALLOF~1\main\localized_english_pak1.pk3 (3736 files)
    localized assets pak file for english
    C:\PROGRA~1\CALLOF~1\main\localized_english_pak0.pk3 (1204 files)
    File Handles:
    11939 files in pk3 files
    execing default.cfg
    couldn't exec language.cfg
    couldn't exec config.cfg
    couldn't exec autoexec.cfg
    ========= autoconfigure
    ----- CL_Shutdown -----
    Hunk_Clear: reset the hunk ok
    configure.csv not found.
    Any ideas of how to fix it?
  2. Solar
    Solar
    Dec 2, 2003
    2,551
    Earth
    +463
    reinstall again
    or installing the update should add new cfg files
  3. iZombine
    iZombine
    Jan 21, 2005
    870
    28
    +33
    Reinstalled it 4 four times and now it seems to work fine.
