Call me Mr Thicky...but
Discussion in 'Home Cinema Speakers' started by bertha, Mar 22, 2002.
  1. bertha
    bertha
    Oct 25, 2001
    1,358
    +116
    Just wondering..I'm in a similr situation to a few of the dudes on this forum in that I am moving into a home that is no longer floorstander friendly & consequently have had to consider the sub sat route...here's what I've been thinking...the likes of the KEF eggs which seem to be the reluctant choice considering the price v performance quandry...how would a set up comprising of say for argument Kef Coda 7's (or newer/similar) X 5 & a sub compare...what I mean is how would 5 smallish bookshelf speakers (shielded of course) with a sub in tow compare to an actual sub/sat system..am I gibbering or is this a viable option (I realise that I would potentially have 1 spare speaker - but this could prove useful for those of a 6.1 bent)...any opinions welcome
    cheers
    Berth:)
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,553
    Newcastle
    +340
    What you suggest should work fine. Use the amp's bass management to send <80Hz to the sub and >80Hz to the "bookshelf" speakers and you're away.
    Cheers,
    Liam
  3. Couch Potato
    Couch Potato
    This is exactly what M&K offer, check out their range atMiller & Kreisel
    Steve
  4. Jase
    Jase
    Mar 16, 2001
    10,735
    United Kingdom
    +2,520
    Most certainly a good idea and will give you better sound than the eggs.
    Set the bass management as Liam has suggested and your in business.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I have just put my Def Tech sub sat system up for sale as I wished to return to the full range speaker plus sub option. The difference depends on the quality of the speakers that you use.
  6. lmccauley
    lmccauley
    Oct 24, 2000
    3,553
    Newcastle
    +340
    And this is exactly the route I am taking - replacing my Monitor Audio floorstanders with M&K S85 and probably a REL Q100E or Paradigm Servo15 sub. :D
    Cheers,
    Liam
  7. bertha
    bertha
    Oct 25, 2001
    1,358
    +116
    thanks all for the feedback I think you've just made my mind up for me - I'm not going to go down the 'official' sub/sat route I think I'll look at the M&K (etc) option...
    cheers for now
    will let you know what I go for in the end..
    Berth
  8. Guest
    Yah got to go for the sony dav500 guy, it will rinse everthing like it.
  9. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,296
    3
    +8,597
    This is not the option that was being discussed. While the Sony Dav range are alright as a lifestyle product, the sound quality is no where near good enough for serious HC. The suggestion to use small bookshelf speakers and a quality subwoofer is the way to go. Try some Kef Crestas and a rel 100e, or B&W 600 series with a rel sub.
  10. Lowrider
    Lowrider
    I woulg get four KEF Q1 + one Q9, + a good subwoofer...
