Calibration using Digital video Essentials
Discussion in 'Home Cinema Buying & Building' started by kid rock, Nov 22, 2004.
  1. kid rock
    kid rock
    Dec 10, 2003
    316
    frankfurt germany and cardiff wales
    +9
    I wasnt sure where to post this issue. I have the DVE dvd and was wondering what is the best way to calibrate the picture on my NEC 1000 and my Pioneer 868. Is it best to say leave the Pj on one of its factory presets and adjust the dvd player or vice versa or a mixture of them being adjusted. DVe doesnt seem to recommend any particular way of doing this. My hunch is its best to adjust the settings on the source and not the display as I recall reading this somewhere once.
    help would be appreciated.
    Kid Rock
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I always calibrate the source, with multiple sources then you can deal with each separately. Ultimately though I don't see any theoretical reason why one would be better than the other.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,979
    +2,780
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    What are you getting at Gordon? If you calibrate the source what's left to do with the display? :confused:
  5. Gordon @ Convergent AV
    Jul 13, 2000
    13,979
    +2,780
    With some sources there is not much you can do, with others there's alot. You must make sure that the output characteristics of the sources are correct before trying to make adjusments in the display.
    If you adjust a DVD player so that it's output isn't crushing black or white detail do you think that means the display is correct?.....possibly...possibly not.
    Adjust the colour output/sharpness in our DVD player so it's component output looks nice do you think that means that other sources sharing the component input of the display will also be correct?.....possibly....possibly not.
    The adjusments I make in the display are not fixeable in sources. If there is a scaler in the middle then you need to have it done properly as well before you work on the display......it's a tricky business.
    Gordon
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Okay, I see what you're saying .. but then that must lead to a frenetic round of
    fix one source
    fix the next
    have to fiddle with the display which means going back to the first source
    then the next
    etc.
    :eek:
