Question Calibration Microphone.
u8myufo
Just finished setting all the gear up after moving house and wanted to re-calibrate the Amp (Sony str-dn1080) and speakers. Only prob is I cannot find the mic. But do have the one from an old Onkyo 818 which I once had, is it likely that it would work?
dante01
You'd need to use the supplied mic or a Sony replacement for it. THe receiver's calibration targets only relate to that mic's profile. A third party mic will not result in a calibration that would be condusive with the stored calibration curves on that AV receiver.
It would allow you to run the calibration, but the results may not be optimimum and or correct?
u8myufo
Cheers, I was thinking that may well be the case, will have to have another search through a shed load of box`s of cables etc. Ya know I put it in one of those safe places so I wouldn`t lose it :laugh:
u8myufo
Whilst i can find a couple of sellers for the original mic, prices seem a bit much. however other searches seem to throw up these. Do you know if the curved flat mic with a left/right sensor was replaced with the round model?
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
