Calibration for Infocus 4805
Discussion in 'Home Cinema Buying & Building' started by Baz1, Nov 10, 2004.
  1. Baz1
    Baz1
    Dec 11, 2002
    169
    16
    Workingon, Cumbria.
    Would someone like to post their projector settings for the 4805.
    Thanks,
    Barry.
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    Yeah mine are Plug in turn on and watch !!!!!!!
    Honestly, it's nigh on perfect straight out of the box. projector Central reckon it can use a slight tweak in the gamma settings. See the link below for the full details:
    http://www.projectorcentral.com/infocus_screenplay_4805.htm
    They say out of the box it has a slightly greenish bias. I can't see it on mine so I think it must have just been their one. The 4805 has apparently been pre-set to "D65" which is the standard colour setting used by Hollywood for their movies, so if you start playing with the settings, I assume you'll lose this , so I say leave well alone and just enjoy the fantastic image Infocus have achieved!
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    Hi Baz1,
    There may be some more user info over on www.avsforum.com - many have colorfacts calibration software, so there might be some listings of adjustments.
    Each calibration setting will be different for each input, so using a component setting for a dvi input may not give the same results. Different DVD players can also affect the settings you'll use, so make sure you note down any settings before you change anything (though if they're all at 50, it's probably not hard to remember:) ).
    HTH
    Gary.
  4. Baz1
    Baz1
    Dec 11, 2002
    169
    16
    Workingon, Cumbria.
    Thanks, boys.
    Barry.
