Calibration DVD for HDTV
Discussion in 'General TV Discussions Forum' started by multiply, Aug 24, 2005.
  1. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    As a relative noob, I've been looking around various home cinema forums and it seems that in order to get the best PQ from your HD TV, it is advisable to get a calibration DVD.
    Having just purchased the Samsung LE26R41BDX (and awaiting delivery), I took the plunge and ordered Digital Video Essentials - dvd.co.uk are selling it for £12.99 inc. delivery, so I thought this was a good investment.
    If anyone is interested, I will post my experiences once I have received both disk and TV and tried to calibrate. I'll be using the Samsung HD950 DVD player, so it should be a true hi-def test.
    In the meantime, if anyone has already experienced this exercise and would like to share any words of wisdom, it would be truly appreciated....
    Cheers,
    Gary
  2. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    950 isn't a HD player, it just upscales DVD (540 lines) to 720/1080.
    You'll need DVE Pro which has a HD disc as part of the package and a PC with MPEG 2 or 4 (not sure which) to decode the signal contained on it.
  3. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    oh.
    So are you saying I won't be able to calibrate the TV with this combo? :(
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,467
    Windsor
    +1,044
    and surely then that would only calibrate your VGA input against the output of the PC you used.
    Realistically though, you could still use digital video essentials, or Avia, or THX optimiser. Most of the tests are about colour, brightness, contrast etc, which should be as valid on a HD set as an SD set.
  5. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    Thanks, Richard.
  6. Andy Leitch
    Andy Leitch
    Apr 27, 2005
    563
    None of your business
    +69
  7. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    Andy,
    Just tried to pm you, but your profile has blocked this.
  8. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    HD is a completely different colour space than SD. Some displays have a problem converting upscaled YUV to RGB HD because of this - I believe you get a shift to green.
    -Ian
  9. richard plumb
    richard plumb
    Jan 27, 2002
    14,467
    Windsor
    +1,044
    understood. But at the end of the day, you will be watching (initially at least) DVDs which are mastered for SD colourspace. Ultimately the aim is to get the DVDs to look as good as possible. Surely it makes sense to use a DVD on the source you will use, as the method of calibration - at least for those sources.
  10. jriihi
    jriihi
    Mar 6, 2005
    196
    16
    Ah thanks Andy. I forgot about that INHD Tuneup thingy :)
  11. Howard Pitfield
    Howard Pitfield
    Nov 17, 2003
    815
    2
    +17
    Used standard DVE on my new Panny LCD - it's still useful for setting up. I went through all the tune ups - the movie segments looked gorgeous. Then switched to Sky and had to change everything back - oh well. As for Freeview (built in) - hmmmmm.
    H
  12. Glib
    Glib
    Aug 25, 2005
    142
    +7
    Can't you save settings for different source inputs?
  13. Howard Pitfield
    Howard Pitfield
    Nov 17, 2003
    815
    2
    +17
    You can indeed - but why use DVE to set up and then Sky via RGB looks different. Guess the new DVD player with upscaling was doing it's job too well!
    H
