Calibrating PW6
Discussion in 'Plasma TVs Forum' started by chrisyd, Oct 18, 2004.
  1. chrisyd
    chrisyd
    Jul 29, 2004
    85
    I have been searching the forum for calibration discs. I would love to get this professional done but I have not cash at the moment after spending it all on my AV equipment.
    Anyway, I have a PW6 which is connected to a Yam 2400 via component cables. I have a multi region DVD player (which I am going to upgrade very shortly). All my original DVD's are region 2. I know I can purchase DVE which is PAL and AVIA which is region 1.
    My question is.. If I were to configure my plasma with AVIA would there be any difference playing back region 2 DVD's in terms of picture/audio quality?
    I hope this makes some sense
    thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ideally you should use both PAL and NTSC calibrations dics DVE is cheap buy both NTSC and PAL for £25 ish..........
