Hi Guys,
Just looking for some advice from someone more vastly experienced than myself. When calibrating a TV with a full array backlit LED lighting system with a hardware meter (using Chromapure If that makes a difference) would you use Window, Fields or APL patterns.
Also in your experience would you calibrate with Local Dimming enabled or disabled (even though you plan to use this after calibration). I have read that this should be disabled.
I have read varying opinions on the level of the backlight setting as well, any experience on this also.
Many thanks in advance
Simon
Simon
