G a f f e r
I own a Panny AE500E (UK model - discount tv)
there are 6 basic viewing tweak modes (normal-dynamic-cinema1-cinema2-video-smooth). - can't quite remember name of last one, but makes image 'smoother'.
Using recent THX video calibration discs, video and smooth are within THX parameters, with normal just about passing (first screen of whites is borderline pass).
However, when I put on an older THX disc (> 2 years), ALL the above modes failed the tests without additional tweaking.
The problem is, there are so many menu's in the AE500, I could probably spend the rest of my life 'tweaking'...
Also, ALL modes look fine with certain films, but other films look better with other modes.
As a result, I end up just switching the mode on a film to film basis (and generally ignoring the THX calibration).
I was just wondering if you're meant to do this or if you are meant to set it up once for DVd (maybe twice if also connect a ps2) and leave it like that? Am I doing something wrong? Also, is there a definitive setup disc I could buy that would leave me with the perfect setup (no need to then continually go into the picture menu)?
PS in case you haven't guessed, I'm a complete newbiw at this - having recieved my first projector last week
