Calibrating AE100 Colours, Contrast etc
Discussion in 'Projectors, Screens & Video Processors' started by Amelia, Jul 25, 2002.
  1. Amelia
    Amelia
    This post may be a bit premature, as I have only tried out my AE100 on a white wall (since the HT Room isn't complete yet), but I did notice the default settings have the colour set too high. I noticed reds are too red and skin tones are not natural. When I turned them down, the picture was much more natural.
    I also checked the default setting on my Panasonic TV and they also seem to be set to high.
    And finally to my question, is there a proper way of setting up the projector other than by eye?
    Best Regards
    Amelia
  2. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    The Avia guide to home theatre dvd is regarded the best :)
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
    I still find Video Essentials far more useful and less long winded
  4. Amelia
    Amelia
    Are these guides in DVD form or Books?
    Regards
    Amelia
  5. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
  6. Amelia
    Amelia
    Thanks you :D
    I will start hunting them down.
    This should be COOL
    Regards
    Amelia
  7. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Errr....I don`t think I`ve seen colour in the menu....How do you change it as I agree it`s very colourful thanks
  8. Amelia
    Amelia
    Hi Walter,
    If I remember correctly (Since I have put my PJ away as the room is being renovated), first click on the Menu button and then once the menu is up, use the up arrow to go to the Picture menu. once you press enter, you will see Colour, Contrast, Brightness etc.
    Hope this helps
    Hey JSW & Mr.D , I have been trying to get my hand on either of these calibration DVDs, but no one seems to have them, can they be purchased from the net and if so where?
    Best Regards
    Amelia
  9. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    Amazon.com
  10. Amelia
    Amelia
    Thanks :D
  11. jrwood
    jrwood
    make sure you pay with a credit card on amazon...
  12. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
  13. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    There's also the Ultimate DVD Platinum available in Australia very cheaply. From what people have said, not as comprehensive, but at AU$24.95.....
    HTH!
  14. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
    If you use the RGB input (PC) you don't get colour (saturation): you can always tweak it at the PC end ( although I tend to go for the scoped settings available form the theatertek forum website)
    If you are using a s-vid composite or component it should be in the picture menu.
  15. Amelia
    Amelia
    Are any of these DVDs for Pal ?
  16. jrwood
    jrwood
    I think there all NTSC..... if you wait a bit there is that new calibration DVD from Sweden? 'The Calibrator' and Video Essentials to be released soon.
  17. Amelia
    Amelia
    Thanks,
    I think I will hold on then for 'The Calibrator'.
    Best Regards
    Amelia
  18. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
    The NTSC/PAL colour issues are such a big deal. If you use PAL60 the black set-up should be 0IRE and the colour should be valid PAL. If you are using RGB or component its even less of an issue ( these should always set-up for 0IRE with RGB its even more fuzzy as the video intensity raneg is being remapped entirely into a linear format )
    In plain english its not such a big deal.
    The other thing to try is the Phantom menace region2 which had a reasonably good PAL THX optimode on it which will handle the bulk of adjustments available to the average user.
