kBm
Looking for recommendations for a calender app? What do you use?
Been using stock Samsung S Planner for a while but it does not have a widget if you decide not to use Touch Wiz. Currently using Simple Calender, but its well, too simple!
It needs to sync with Google calender and google task, plus display on the home screen as a month view grid.
I've seen Jorte is popular, it is any good? Same with Business Calender.
Cheers all
Cheers all
