Calendar App
Discussion in 'iPhone Forum' started by DanParker, Jan 5, 2012.
Tags:
  1. DanParker
    DanParker
    Jun 24, 2010
    502
    +77
    Sorry if been asked previously but I can't seem to get any relevant search results using the AVF app.
    Does anyone know of a calendar app which has the ability to create repeat appointments on a four weekly basis? Also the functionality to give you the option when to remind you instead of being limited to just two days before the event? (Like the default calendar app)
    I know you can sync calendars with google etc but I would prefer to do all the work on my phone and google calendar's mobile site is pretty useless.
  2. DanParker
    DanParker
    Jun 24, 2010
    502
    +77
    To anyone who is interested I have found an app which suited my needs on the app store called Pocket Life calendar. Free to try and £1.99 to remove ads.
    Can set appointments/reminders at any frequency, ability to set custom reminders at any point before the event. All sorts of custom display options. Also syncs with default app. Very nice
