Cabling
Discussion in 'Hi-Fi Stereo Systems & Separates' started by markp, Oct 14, 2003.
  1. markp
    markp
    Sep 27, 2003
    258
    28
    Derby
    +25
    I hear a lot about buying the right cable and how this makes a difference.
    Monster cable (www.monstercable.com) claim that they can reduce jitter so digital sound is less colder and more realistic.
    What exactly is happening in the cable (ie the electrons) to make the difference?
  2. markp
    markp
    Sep 27, 2003
    258
    28
    Derby
    +25
    Maybe I have answered my own question. It seems that resistance is the main (only) concern according to this site
    The upshot is that it's a waste of money buying expensive speaker cable. Comments?
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Markp....not sure whether you're asking about digital interconnects or speaker cables here....or both.
    You will find that a search on either topic here should bring a wealth of opinion on both.
    As far as digital cabling goes,it's not just the impedance(which should be 75ohm for digital)but also the quality of the cable,it's shielding,and the cable terminations....so much has been written on this,that I won't go further than to say that with good equipment,good cabling makes a big contribution.
    The same can be said for good quality speaker cables,partnered with good amps and speakers....there's relatively little point in buying very expensive cables for inexpensive gear,if you're not planning on an upgrade.
