Cabling
A
a1rajput
Hi All
I am in the process of cabling my rear speakers, as I have wooden flooring, I have a problem in hiding the running cables, I can overcome this problem, if I bring the speaker cable from outside(garden). My worry is, would it effect the performance of anything of anykind, as the cables I am using are normalthick cables from B&Q ?
Please Advice.
R
recruit
a1 - If you are thinking of running cables outside they need to be weather proof and more importantly water proof otherwise you could damage you're speakers and electronics.
Personally i would try and keep cableing inside for peace of mind.
John
A
a1rajput
Cheers mate! Any suggestions, how can I do this with wooden flooring?
Filbert
Does the edges of your wood flooring have beading? If so, remove the beading, hide the cabling behind it, and then rpelace with the same, or wider beading if needed.
Podcast: Philips OLED+935 impressions, Denon AVC110 Review, Film Reviews, News and More...
