Cabling up for mums freeview?
Discussion in 'Cables & Switches' started by 9761, Jun 7, 2005.
  1. 9761
    9761
    May 16, 2005
    499
    My mum has just came back from work with a freeview box :thumbsup: , exactly the same as mine for the moment :lesson: (Goodmans GDB3) and she asked me what cables to get that where good, she knew ive just brought some for my TV so, my question is should she buy a RGB only scart and 2 audio phono leads both from QED or just stick with a fully wired Scart?
    Which would give better results?
  2. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    There are those around here that swear by RGB only, but as I've said many times before, I've never had any problem with fully wired.
