Cabling requirements
Discussion in 'Cables & Switches' started by chriskenny, May 19, 2005.
  1. chriskenny
    chriskenny
    Can anyone please help as I am a relative novice to the Home Cinema experience. I have just purchased the following- Pioneer 435xde, Denon 3805 and Denon 3910. I use the system (99%) of the time purely for movies/DVDs. I wish to run thru' HDMI and as such purchased the Chord Supra Silver HDMI cable. What r my other cable requirements and their connections? All replies would make me eternally grateful :clap:
    Ps I am more than likely to purchase the speaker system KEF KHT 5005
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    You'll need something to get the sound info from the DVD to the receiver (a digital connection, either optical or coaxial). You'll need some speaker cable also, personally I'd recommend twin and earth or cat5, but then I always say that. do a a quick search if you're not familiar with the terms, there's loads on this forum about both.
