Cabling question
Discussion in 'Cables & Switches' started by mobily, May 18, 2005.
  1. mobily
    mobily
    Dec 30, 2003
    504
    Plymouth
    +3
    Hey all,
    I have a question regarding hooking up a freeview or sky box to an amplifier. Is it better to connect using phonos or the digital connection? I always thought that if you connected through digital the amp would perform the DAC process. Am I wrong in thinking this?
    I currently connect my digital radio using phonos rather than digital.
    Cheers,
    James :)
  2. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    there is no digital connection on a sky box, however there is an optical connection on sky+, which if you want to receive 5.1 sound you will have to use.
    Some freeview have optical connection and I would use this before the phono's
  3. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    The Sony Sky boxes have an optical digital output.
    If your amp has a suitable digital input I would use that rather than the analogue inputs.
