rwttm001
Hi guys
Took the plunge on the PH9 this morning!
Some good advice from members of this forum, choddo, MAW etc made me see I could connect everything I needed to the panel.
However I need a little bit more help to see me through! I'm going to replace my existing no-name SCARTs (to go from DVD/Sky and Sky to JS Tech Box RGB2VGA), would either of these be ok?
Profigold PGV782 - http://www.clearly-av.co.uk/PGV782.html
QED P2105 - http://www.empiredirect.co.uk/content/products/details/index~modelcode~QED-P2105.htm
I'll also need a VGA-VGA cable and a cable to carry sound from the RGB2VGA to the panel, can anyone recommend any reasonably priced ones? Would a cheap one from eBay suffice?
Finally I'm looking for some bookshelf speakers in black and cable to connect from the panel to the speakers (whereabouts on the panel do I connect this?)
Thanks very much guys
