Cabling help!!
Discussion in 'Cables & Switches' started by videonasty, Nov 3, 2004.
  1. videonasty
    videonasty
    Feb 12, 2004
    2,274
    West Midlands
    +39
    I need some advice on speaker cabling :confused: I was thinking about using the IXOS XHS233 for my rears, using QED Original for my fronts/center speakers, then finishing it off by purchasing a sub cable & component cable from Mark Grant. :boring:
    Will the cables I have mentioned do a great job? :smashin:
