cabling help needed
dapex
Hi there, I have decided I would like a Z2, but i cant afford to upgrade my dvd player ect all at once. I have an xbox that will provide component output, a sky box that will give me s-video output and the only spare output on my dvd player is composite.
Ideally i dont want to mess about unplugging things etc everytime i want to use the PJ, that is why I am only conecting up spare outputs.
Is there an easier way than having to run all these different leads to the PJ I.e a box that will take all the inputs and then just give me component or dvi out????
Dave
Joe Fernand
AVForums Sponsor
Dave
Yes plenty of options but not light on the wallet - a decent single box solution with multiple video inputs and a single 'processed' YUV or RGB over Analogue or Digital cable will cost you £500+; the DVDO iScan Ultra or UltraHD (£950) being contenders for your cash (see http://www.dvdo.com) along with the soon to be released Lumagen VisionDVI (£800); this unit is Digital out only (see http://www.lumagen.com)
A lower cost option being to convert everything to Analogue YUV: if you have an AV Receiver with YUV switching you can convert the RGB out of your Digibox to YUV using a JS Technology RGB2YUV converter (£150) and then simply send all of your signals vai yoru AV Reciver as Analogue YUV to the projector over a suitable cable.
If you don't have an AV Receiver with YUV switching you can add in a high quality external YUV (+ Digital audio) switcher to your set up for under £250 (see http://www.zektor.com).
Best regards
Joe
Sony A90J & A80J OLED and X90J & X95J BRAVIA XR TV Line-up & Features: Sony Interview
