Cabling from sources to projector..
Discussion in 'Projectors, Screens & Video Processors' started by tomacwhite, Oct 25, 2003.
  1. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    I have looked up and down numerous times on the front page to see a dedicated section for interconnections and cabling, but can't find it, so I'll ask here if thats ok?
    I am just after some recommendations on places to get RGB SCART leads, phono leads and VGA leads online?
    I am after some nice stuff, but no stupidly expensive etc. £50 for a 10m SCART cable etc, that sort of price range really. I will be using phonos for my component connection as various sources have told me there is no difference really. I'd obviously be best buying a nice set of phonos, at 10m again.
    Any ideas/recommendations would be appreciated.
    Thanks.
  2. Kramer
    Kramer
    For VGA, DVI etc. try Lindy.
    :smoke:
